DIMLWD system variable
Dim line lineweight
Specifies the lineweight of dimension lines.
| Type: | Short |
| Saved in: | Drawing |
| Range: |
-3 to 211 |
| Default value: | Bylayer |
| Possible values: |
-3: Default (defined by LWDEFAULT) -2: ByBlock -1: ByLayer 0 - 211: Lineweight value in hundredths of millimeters |
