DIMSAH system variable
Arrowheads
Controls how dimension line arrowhead blocks are set.
Tipo: | Booleana |
Salvato in: | Disegno |
Valore predefinito: | 0 |
Valori possibili: |
Off (0): Set by DIMBLK - uses the same block for the first and the second arrowhead On (1): Set by DIMBLK1 and DIMBLK2 - uses different blocks for the first and the second arrowhead |
