DIMTVP system variable
Text offset vert
Specifies the vertical position of dimension text above or below the dimension line when DIMTAD=0. The offset equals the product of DIMTVP and the height of the dimension text (DIMTXT). Setting DIMTVP to 1.0 is equivalent to DIMTAD=1
| Type: | Real |
| Saved in: | Drawing |
| Default value: | 0.0 |
