DISPLAYSIDESANDENDS system variable
Display sides and ends
When ON, the sides and ends of linear solids highlight on hovering if the Quad is ON or bitcode 1 of the SELECTIONPREVIEW system variable is selected. The variable is available in the BIM and Ultimate license level only.
BricsCAD only
| Type: |
Boolean |
| Saved in: |
Drawing |
| Default value: |
Off |
| Possible values: |
Off (0): Don’t display sides and ends On (1): Display side and ends |
