DMPUSHPULLSUBTRACT system variable
DMPUSHPULL subtract
Specifies if a solid that intersects with other solids during a PUSHPULL operation subtracts from the existing solid.
BricsCAD only
| Type: | Boolean |
| Saved in: | Workspace |
| Range: | 0 to 1 |
| Default value: | Off |
| Possible values: |
Off (0): Disable DMPUSHPULL subtract On (1): Enable DMPUSHPULL subtract |
