DRAWINGVIEWPRESETTRAILING system variable
Drawing view trailing lines preset
Stores the current trailing lines preset for VIEWBASE command.
BricsCAD only
| Type: | Boolean |
| Saved in: | Registry |
| Default value: | On |
| Possible values: |
Off (0): Don’t store the current trailing lines preset On (1): Store the current trailing lines preset |
