DXEVAL system variable
Data extraction update mode
Specifies the notification for data extraction tables. The value is stored as a bitcode using the sum of the values of all selected options.
| Type: | Short |
| Saved in: | Drawing |
| Range: | 0 to 511 |
| Default value: | 12 |
| Possible options: |
0: No notification 1: Notification on open 2: Notification on save 4: Notification on plot 8: Notification on publish 16: Notification on ETRANSMIT or ARCHIVE 32: Notification on save + automatic update 64: Notification on plot + automatic update 128: Notification on publish + automatic update 256: Notification on ETRANSMIT or ARCHIVE + automatic update |
