DYNDIMDISTANCE system variable
Dynamic dimension distance
Specifies a factor for the distance between the dynamic dimension line and the grip points being dimensioned (default: 0.0).
BricsCAD only
| Type: | Real |
| Saved in: | Preference |
| Range: | 0.0 to 10.0 |
| Default value: | 1.0 |
