DYNDIVIS system variable
Dynamic dimension visibility
Specifies how many dynamic dimensions are displayed while moving grips.
| Type: | Short |
| Saved in: | Registry |
| Range: | 0 to 2 |
| Default value: | 1 |
| Possible values: |
0: Only the first dynamic dimension 1: Only the first two dynamic dimensions 2: All dynamic dimensions, as specified by DYNDIGRIP |
