EXPINSFIXANGLE system variable
Explorer Insert Fix Angle
Uses a rotation angle for blocks inserted from the Drawing Explorer. See also the EXPINSANGLE system variable.
Solo-BricsCAD
Tipo: | Booleana |
Salvato in: | Preferenza |
Valore predefinito: | On |
Valori possibili: |
Off (0): Don’t insert blocks at fixed angle On (1): Insert blocks at fixed angle |
