EXPORTGEOMETRYFLAGS system variable
Export Geometry Flags
Controls geometry representation in IGES and STEP formats. The Split Pcurves at G1 Discontinuities flag is currently supported only when exporting without product structure.
| Type: |
Short |
| Saved in: |
Registry |
| Range: |
0 to 15 |
| Default value: |
0 |
| Possible values: | 01: Convert Analytical Curves to Splines 02: Convert Analytical Surfaces to Splines 04: Split Pcurves at G1 Discontinuities 08: Split Periodic Faces |
