EXTRUDEINSIDE system variable
Resolve intersection with parent entity.
Determines how to modify the parent entity when it intersects with the extruded/revolved entity when the Auto option of the EXTRUDE or REVOLVE command is selected. Parent entities are entities that touch the contour from which the extruded/revolved entity is created.
The EXTRUDEINSIDE system variable is one of the four system variables found under the Extrude mode group.
BricsCAD only
| Type: |
Short |
| Saved in: |
Workspace |
| Range: |
0 to 2 |
| Default value: |
0 - for Workspaces Drafting and Modeling 1 - for Workspaces Mechanical and BIM |
| Possible options: |
0: Do not modify the parent entity. 1: Subtract the created entity from the parent entity. 2: Unite the created entity with the parent entity. |
