FIELDEVAL system variable
Field update mode
Specifies the way fields are updated. The value is stored as a bitcode using the sum of the values of all selected options.
| Type: |
Short |
| Saved in: |
Drawing |
| Range: |
0 to 31 |
| Default value: |
31 |
| Possible options: |
0: Not updated 1: Updated on open 2: Updated on save 4: Updated on plot 8: Updated on use of ETRANSMIT 16: Updated on regeneration |
Note: Date fields are only updated by the UPDATEFIELD command; they are not automatically updated based on the FIELDEVAL system variable value.
