FILEDIA system variable
File dialog
Toggles the display of file dialog boxes. If FILEDIA is Off, you can still get a file dialog if you type a tilde (~) at the command prompt. This procedure also counts for LISP functions and command fields in tool definitions.
| Type: | Boolean |
| Saved in: | Registry |
| Default value: | On |
| Possible values: |
Off (0): Don’t display file dialog boxes On (1): Display file dialog boxes |
