FILLMODE system variable
Fill mode
Shows fills for multilines, traces, solids, hatches (includes solid-fill), and wide polylines.
A REGEN is required.
If off, all filled entities display and print as outlines, this will also reduce the time it takes to display or print a drawing.
Tipo: |
Booleana |
Salvato in: |
Disegno |
Gamma: |
On |
Valori possibili: |
Off (0): Entities are not filled On (1): Entities are filled |
