FITLINEFITARCMODE system variable
FitLine FitArc mode
The FITLINEFITARCMODE system variable sets the values for the options Use entire drawing, Fit in 3d, and Delete original entities after fitting, that are used by the FITLINE and FITARC commands. The value is stored as a bit code using the sum of the values of all selected options.
| Type: |
Byte |
| Saved in: |
Registry |
| Range: | 0 to 255 |
| Default value: | 0 |
| Possible values: |
0: None 1: Use entire drawing 2: Fit in 3D 4: Delete original entities after fitting |
