GENERATEASSOCVIEWS system variable
Generate associative drawings
Specifies associativity between the 3D model and generated views (VIEWBASE) and calculated drawings (BIMSECTIONUPDATE). As a result dimensions are updated in the associated paperspace viewports and BIM section drawings.
BricsCAD only
| Type: |
Boolean |
| Saved in: |
Workspace |
| Default value: |
Off |
| Possible values: |
Off (0): Disable associative dimensions On (1): Enable associative dimensions |
