GRADIENTMODE system variable
Background gradient mode
Specifies if and how a gradient is to be applied in the default background (this is only used as a default value for the Background dialog).
BricsCAD only
| Type: | Short |
| Saved in: | Preference |
| Range: |
0 to 2 |
| Default value: | 0 |
| Possible values: |
0: No gradient background 1: Two-color gradient (top/bottom) 2: Three-color gradient (top/middle/bottom) |
