HOTKEYASSISTANT system variable
Hotkey Assistant
Specifies whether to display the Hotkey Assistant widget or not.
BricsCAD only
| Type: | Boolean |
| Saved in: | Registry |
| Default value: |
On |
| Possible values: |
Off (0): Don’t show Hotkey Assistant widget On (1): Show Hotkey Assistant widget |
