HPMAXCONTOURPOINTS system variable
Maximum number of points on a hatch contour
Controls the maximum number of points on a contour (outline) that a hatch entity can contain and still render.
Values between 0 and 10,000,000 are accepted.
Hatches do not render if the number of points exceeds the specified value.
Setting to 0 disables the check, meaning the variable is not used.
Solo-BricsCAD
Tipo: |
Breve |
Salvato in: |
Registro di sistema |
Gamma: |
0 to 10000000 |
Valore predefinito: |
100000 |
