IFCMATCHIMPORTEDPROFILESGEOMETRICALLY system variable
Import: use profiles from databases with corresponding geometry
During import, profiles will consecutively be compared with the project and central database based on their geometry. In case of a match, the parameters defined in the project/central database (profile name, size and standard) will be used instead of the imported parameters.BricsCAD only
| Type: |
Boolean |
| Saved in: |
Registry |
| Range: |
0 to 1 |
| Default value: | 0 |
