INSBASE system variable
Insertion base point
The drawing's insertion point, used when the drawing is inserted into other drawings as a block. Set by the BASE command, and expressed as a UCS coordinate for the current space.
Tipo: |
Punto 3D |
Salvato in: | Disegno |
Valore predefinito: |
0,0,0 |
