LAYLOCKFADECTL system variable
Locked layer fade control
Specifies the fading level for entities on locked layers to contrast them with entities on unlocked layers and reduces the visual complexity of a drawing. Entities on locked layers are still visible for reference and for object snapping. Non-positive values disable fading.
| Type: | Short |
| Saved in: | Registry |
| Range: |
-90 to 90 |
| Default value: |
50 |
