LINEARBRIGHTNESS system variable
Linear brightness
Specifies a scaling factor for the intensity of lights. A value between -10 and 10 is accepted. The default value of 0 results in no scaling. Smaller values decrease light intensity and bigger values increase light intensity. This setting can be specified per viewport.
| Type: | Short |
| Saved in: | Drawing |
| Range: |
-10 to 10 |
| Default value: |
0 |
