LOFTPARAM system variable
Loft param
Specifies the shape of lofted surfaces and solids. The value is stored as a bitcode using the sum of the values of all selected options.
| Type: | Short |
| Saved in: | Drawing |
| Range: |
0 to 15 |
| Default value: |
7 |
| Possible options: |
0: No parameters 1: No twist between cross sections 2: Align directions of cross sections 4: Create simple surfaces and solids 8: Close between the starting and ending cross sections |
