LTGAPSELECTION system variable
Linetype gap selection
Specifies whether selection or snapping to the gaps on entities defined with non-continuous linetype is possible.
| Type: | Boolean |
| Saved in: | Registry |
| Range: | Off |
| Possible values: |
Off (0): No selection or snapping within gaps (legacy behavior) On (1): Selection or snapping within gaps |
