MASSPROPACCURACY system variable
Mass properties calculation relative accuracy
Specifies the accuracy to be used for mass properties calculations. This accuracy is relative: the accuracy of the result depends on the magnitude of the calculated value. Acceptable value Range: 2 - 12 (0.01 to 0.000000000001, or 1.e-2 to 1.e-12).
BricsCAD only
| Type: | Short |
| Saved in: | Preference |
| Range: |
2 to 12 |
| Default value: |
2 |
| Possible values: |
2: 0.01 3: 0.001 4: 0.0001 5: 0.00001 6: 0.000001 7: 0.0000001 8: 0.00000001 9: 0.000000001 10: 0.0000000001 11: 0.00000000001 12: 0.000000000001 |
