MECHANICALBLOCKS system variable
Mechanical blocks (experimental)
Enables or disables mechanical blocks (experimental feature) as an alternative to mechanical components.
BricsCAD only
| Type: |
Boolean |
| Saved in: |
Registry |
| Default value: |
On |
Off (0): Disables mechanical blocks On (1): Enables mechanical blocks |
