MENUECHO system variable
Menu echo
Specifies menu echo and prompt control. The value is stored as a bitcode using the sum of the values of all selected options.
| Type: | Short |
| Saved in: | Not saved |
| Range: |
0 to 15 |
| Default value: |
0 |
| Possible options: |
1: Suppress menu item echo 2: Suppress system prompts during menu 4: Disable ^P toggle 8: Display input/output strings (DIESEL macros debugging) |
