MTEXTFIXED system variable
Multiline text fixed
Specifies whether BricsCAD zooms, rotates and/or pans the view to fit the multiline text being edited.
| Type: | Short |
| Saved in: | Registry |
| Range: |
0 to 2 |
| Default value: |
2 |
| Possible values: |
0: Do nothing when mtext editor is opened 1: Do nothing when mtext editor is opened 2: Rotate / zoom / pan view to fit multiline text |
