MTFLAGS system variable
Multi-Threading Flags
Bit flags for parallel processing of display and loading.
Tipo:
Breve
Salvato in:
Registro di sistema
Gamma:
0 to 4095
Valore predefinito:
3015
Possibili opzioni:
0: No parallel processing
1: Parallelized regeneration of display.
2: Parallelized redraw of display.
4: Parallelized loading of drawings.
8: Parallelized calculation of hidden line removal.
16: Parallelized generation of BIM sections to separate destination files.
32: Parallelized generation of BIM sections to the same destination file.
64: Parallelized computations in Direct Modeling commands and operations.
128: Parallelized computations in Assembly commands and operations.
256: Parallelized computations in Sheet Metal commands and operations.
512: Parallelized interference checking
1024: Delayed XREF loading
2048: Parallelized point cloud operations
