OBJECTISOLATIONMODE system variable
Object Isolation Mode
Specifies whether entities that are temporarily hidden with HIDEOBJECTS or ISOLATEOBJECTS remain hidden after saving and reopening the drawing.
| Type: | Short |
| Saved in: | Registry |
| Range: |
0 to 3 |
| Default value: |
0 |
| Possible values: |
0: Entities are temporarily hidden for the current session. Interfered solids are selected together with the interference solids. 1: Entities remain hidden between sessions. Interfered solids are selected together with the interference solids. 2: Entities are temporarily hidden for the current session. Interfered solids are not selected together with the interference solids. 3: Entities remain hidden between sessions. Interfered solids are not selected together with the interference solids. |
