OLEQUALITY system variable
OLE quality
Specifies the default plot quality of OLE (Object Linking & Embedding) entities. When set to 3 (Automatic), the quality level is assigned automatically depending on the entity e.g. photographs are set to High.
| Type: | Short |
| Saved in: | Registry |
| Range: |
0 to 3 |
| Default value: |
3 |
| Possible values: |
0: Monochrome 1: Low graphics 2: High graphics 3: Automatically Select |
