OLESTARTUP system variable
OLE startup
Specifies whether or not the OLE (Object Linking & Embedding) entity source application is launched when plotting.
| Type: | Boolean |
| Saved in: | Drawing |
| Range: | Off |
| Possible values: |
Off (0): Don’t load OLE source application when plotting On (1): Load OLE source application when plotting |
