OSNAPZ system variable
Ignore entity snap elevation
Replaces the Z coordinate of the entity snapping point with the current value of the ELEVATION system variable.
| Type: | Boolean |
| Saved in: | Not saved |
| Default value: | Off |
| Possible values: |
Off (0): Don’t replace Z value with current elevation On (1): Replace Z value with current elevation |
