OSOPTIONS system variable
Entity snap options
Suppresses entity snaps on certain entity types: hatches and/or dimension extension lines or negative z-values in dynamic UCS mode. The value is stored as a bitcode using the sum of the values of all selected options.
Tipo: | Breve |
Salvato in: | Registro di sistema |
Gamma: |
0 to 7 |
Valore predefinito: |
7 |
Possibili opzioni: |
1: Entity snap ignores hatches 2: Entity snap ignores negative Z values in Dynamic UCS mode 4: Entity snap ignores end points of dimension extension lines |
