OVERKILLLAYER system variable
Duplicate Entities Layer
This is the layer to which entities are moved when using the option to Move duplicates to Duplicate Entities layer in the OVERKILL command.
BricsCAD only
| Type: | String |
| Saved in: | Registry |
| Default value: |
"Duplicate Entities" |
