PARAMETERCOPYMODE system variable
Parameter copy mode
Specifies copying of constraints and related parameters when entities are copied.
| Type: | Short |
| Saved in: |
Registry |
| Range: | 0 to 4 |
| Default value: | 3 |
| Possible values: | 0: Do not copy 2D constraints 1: Replace all expressions with constants 2: Use existing parameters, if parameter is missing replace it with constant 3: Use existing parameters, create new parameter if it is missing 4: Use existing parameters, create new parameter if it is missing or has different value |
