PDFIMPORTASBLOCK system variable
Import as block
Imports the PDF file as a block instead of directly into modelspace.
BricsCAD only
| Type: | Boolean |
| Saved in: | Preference |
| Default value: |
Off |
| Possible values: |
Off (0): Don’t import PDF files as a block On (1): Import PDF files as a block |
