PDFIMPORTCONVERTSOLIDSTOHATCHES system variable
Convert solid fills to hatches
Converts 2D solid entities into solid-filled hatches.
BricsCAD only
| Type: | Boolean |
| Saved in: | Preference |
| Default value: |
Off |
| Possible values: | Off (0): Don’t convert solid fills to hatches from imported PDF files On (1): Convert solid fills to hatches from imported PDF files |
