PDFIMPORTUSEIMAGECLIPPING system variable
Clip images
Clips images during a PDF import. The clipped part images becomes transparent.
Note: Applies only if PDFIMPORTUSECLIPPING is on (1).
Solo-BricsCAD
Tipo: |
Booleana |
Salvato in: |
Preferenza |
Valore predefinito: |
OFF |
Valori possibili: |
Off (0): Images are not clipped on import On (1): Images are clipped on import |
