PDFNOTIFY system variable
PDF notify
Enables/disables the notification about missing or modified PDF documents when opening the parent drawing.
Solo-BricsCAD
Tipo: | Booleana |
Salvato in: |
Registro di sistema |
Valore predefinito: |
OFF |
Valori possibili: | Off (0): Disable PDF notification On (1): Enable PDF notification |
