PDFNOTIFY system variable
PDF notify
Enables/disables the notification about missing or modified PDF documents when opening the parent drawing.
BricsCAD only
| Type: | Boolean |
| Saved in: |
Registry |
| Default value: |
Off |
| Possible values: | Off (0): Disable PDF notification On (1): Enable PDF notification |
