PICKAUTO system variable
Selection window behavior
Controls the selection behavior - window and lasso - used to select multiple entities at the same time.
See also the PICKDRAG system variable.
Tipo: |
Breve |
Salvato in: |
Registro di sistema |
Gamma: |
-7 to 7 |
Valore predefinito: |
5 |
Possibili opzioni: |
Negative: No window selection, saving earlier value 0: No window selection 1: Window selection, pick the first and last point, if the cursor does not start above an entity 2: Window selection, for click and drag, if the cursor starts above an entity 4: Lasso selection, for click and drag, if the cursor does not start above an entity |
Note: A negative value is the same as 0, but helps in storing the earlier value.
