PICKAUTO system variable
Pick automatic
Specifies automatic window selection (inside or crossing) while selecting entities. The value is stored as a bitcode using the sum of the values of all the selected options. A negative value is the same as 0, but helps storing the earlier value.
| Type: |
Short |
| Saved in: |
Registry |
| Range: |
-7 to 7 |
| Default value: |
5 |
| Possible options: |
Negative: disables window selection 1: Draws a selection window if the mouse is not over any entity when clicked 2: Draws a selection window if the mouse is clicked and dragged over an entity 4: Draws a selection lasso if the mouse is not over any entity when clicked |
