PICKBOX system variable
Pick box
Specifies the size (in pixels) of the small square at the end of the selection cursor (the entity selection target) . If you select an entity by clicking, the Pick Box must touch or overlap the entity. Values between 0 and 50 are accepted.
| Type: | Short |
| Saved in: |
Registry |
| Range: | 0 to 50 |
| Default value: | 4 |
| Unit | pixels |
