PICKDRAG system variable
Pick drag
Controls the window selection behavior used to select multiple entities at the same time.
See also the PICKAUTO system variable.
Tipo: | Booleana |
Salvato in: | Registro di sistema |
Valore predefinito: | 0 |
Valori possibili: | Off (0): Draw selection window with two points On (1): Draw selection window with click and drag |
