PICTUREEXPORTSCALE system variable
Picture format export scale factor
This is the scaling factor that controls the output resolution for exporting to picture formats (WMF, EMF, BMP). The output view size is current viewsize (in pixels) multiplied by this factor.
Used in commands EXPORT, WMFOUT, COPYCLIP, CUTCLIP and in COM/VBA function AcadDocument.Export. WARNING scale values of 10 or more may cause slow system response.
BricsCAD only
| Type: | Real |
| Saved in: | Preference |
| Range: | 0.0 or greater |
| Default value: | 1.0 |
