PICTUREEXPORTSCALE system variable
Picture format export scale factor
Controls the output resolution scale for WMF, EMF or BMP exports. Used in commands EXPORT, WMFOUT, COPYCLIP, CUTCLIP and in COM/VBA function AcadDocument. The output view size is the current view size-in pixels, multiplied by this value.
Trouble: Scale values of 10 or more may cause slow system response.
Solo-BricsCAD
| Tipo: | Reale |
| Salvato in: | Preferenza |
| Gamma: | 0.0 or greater |
| Valore predefinito: | 1.0 |
