POINTCLOUDHSPC system variable
Point Cloud format (hspc/bcad)
Specifies the format used for processing point clouds (hspc or bcad).
Note: The HSPC file format (Hexagon Smart Point Cloud) is a proprietary format developed by Hexagon VCH (Visual Computing Hub). Using this format enables storing per point information which will be used to have more point cloud functionalities (in the future).
BricsCAD only
| Type: |
Boolean |
| Saved in: | Preference |
| Default value: |
On |
| Possible values: |
Off (0): Use bcad format. On (1): Use HSPC format |
